Motor mount issue
Old Aug 17, 2016 | 07:22 PM
1971raresx's Avatar
Motor mount issue
Installing my rebuilt 455 and trans into the car and having issues with the new motor mounts. New motor mounts have part number 2328 whereas the original motor mounts have part number 2308. It seems as if the new motor mounts recommended through most part places do not fit properly. I can't get the motor mount screws through the holes to line up. Has anyone had this problem before or do the new style motor mounts need to be modified? Trying to find a pair of motor mounts with the original part number, but haven't had any luck yet. Any suggestions? Thanks
Old Aug 18, 2016 | 05:50 AM
Have you tried the Search function?
https://classicoldsmobile.com/forums...tion-list.html
Old Aug 18, 2016 | 06:59 AM
There is not such thing as a P/N 2308 motor mount, so either it's a typo or you misread it. The correct mount that matches the 1969-1972 BBO frame mounts is a 2328. If the problem you are having is that the holes for the bolts that go to the block do not line up, this is unfortunately all too common with the Chinesium mounts sold today. I've had to slot those misdrilled holes with a die grinder on more than one occasion.
Old Aug 18, 2016 | 07:52 AM
442Harv's Avatar
I also have had the problem getting the bolt through the mounts. If not real far off, I loosen the mount on the engine, so it moves a round a little, and the when in place, tighten it up.
Old Aug 18, 2016 | 08:22 AM
That's another good point. I always leave the mount-to-block bolts loose, install the cross bolts to the frame mounts, and THEN tighten the bolts to the block.
Jameskilcer
Nov 7, 2015 04:45 AM
1yesfan
Aug 4, 2015 06:40 PM
Dead Reckon
Jul 14, 2014 02:35 PM
jesseb
Jul 25, 2012 09:11 PM
mcutlass1969
Jul 18, 2006 01:58 PM
