motor mount issue
Old Jul 15, 2012 | 01:45 PM
jesseb's Avatar
motor mount issue
bought a new mount for my cutlass yesterday. don't line up at all with the frame mount. the through bolt hole is about an inch too low on the mount itself. anyone run into this? car is a 71 cutlass S. maybe a mismade part?
Old Jul 15, 2012 | 03:47 PM
Does it look like the old motor mount? Did you double check the part number to make sure it was correct?
Old Jul 15, 2012 | 05:03 PM
ah64pilot's Avatar
If your car came stock with a 350 in it then your frame mounts are most likely 350 frame mounts. If it doesn't look the same as the old mount you pulled out you should take it back and have the parts house pull a 350 mount to compare. You can use either mount for a 350 or 455 but the motor mount has to match the frame mount.
IE, if you have 350 frame mounts buy 350 motor mounts for your 455. If you have 455 frame mounts then buy 455 motor mounts.
Old Jul 15, 2012 | 07:11 PM
jesseb's Avatar
That may be the issue pilot. just pulled a junk 307 out of it. used one mount from it, the other was broken. didn't realize they used diff mounts. I'll get another small block mount, see if that cures it. Thanks for the help.
Old Jul 25, 2012 | 08:20 AM
Is it time for a motor mount thread again? Here ya go. Search is your friend.
https://classicoldsmobile.com/forums...tion-list.html
Old Jul 25, 2012 | 12:44 PM
jesseb's Avatar
That was the issue Steve. Not sure why they did that, but it fixed it. Thanks for the help!
Old Jul 25, 2012 | 09:11 PM
ah64pilot's Avatar
LOL! Hey, some of us little guys need to look smart once in a while Don't go ruining it for us by posting links to your past wisdom, haha!
I'm glad it worked out...
1yesfan
Aug 4, 2015 06:40 PM
Dead Reckon
Jul 14, 2014 02:35 PM
Zeeman57
Sep 9, 2008 08:05 AM
Zeeman57
Jun 12, 2007 12:44 PM
mcutlass1969
Jul 18, 2006 01:58 PM
