Progress on 55 Olds 98
Old Nov 19, 2019 | 06:12 AM
69Chrgr's Avatar
Got the new steering box, master cylinder installed, new 2 piece rear main seal and oil pan gasket, turn signal switch and now rebuilding front suspension.
Old Nov 19, 2019 | 07:56 AM
ub2693v's Avatar
How big of a pain is it to remove the brake master cylinder? Mine is completely locked up from sitting so it needs a rebuild, at first glance it doesn't look like a lot of fun getting to the vacuum hoses or the hydraulic pipes.
Old Nov 19, 2019 | 07:58 AM
Tedd Thompson's Avatar
Keep it up and there will be a car soon under all those new parts. What is next?.... Tedd
Old Nov 19, 2019 | 12:28 PM
redoldsman's Avatar
Proud Viet Nam Veteran
It comes out from inside the car. Move the pedal back and there is a panel in the floorboard that the treadlevac attaches to that is bolted to the floorboard. Take the brake lines and the vacuum hose loose and then you can pull it out. If you don't have a factory shop manual you need to get one. It is the best thing you can buy for your car.
Old Nov 20, 2019 | 03:56 AM
69Chrgr's Avatar
redoldsman is correct. You remove the pedal back and there is a floor board panel. It's a pain to remove the brake lines and vacuum hose but after you remove the bolts from inside, drop it (It's heavy) out the bottom of the car. And yes, the shop manual is a huge benefit.
Old Nov 20, 2019 | 03:58 AM
69Chrgr's Avatar
Next is rebuilding the centerlink, replacing the tie rod ends, and wheel bearings. Then back up top to address the carburetor issues. I think there is a check valve for vacuum that I want to look at that could be causing some brake issues.
Old Nov 20, 2019 | 05:34 AM
ub2693v's Avatar
I vaguely remember doing one on my 56' super 88 but that was 20 years ago, I have a 1956 model shop manual, is it worth it to get one for the 1955 model year or are they close enough? The power steering gear is for sure different between 55 and 56, but otherwise they look very similar.
Old Nov 20, 2019 | 05:52 AM
69Chrgr's Avatar
I would try to get one for the 55. It appears a few minor things changed after 55.
Old Nov 20, 2019 | 06:09 AM
redoldsman's Avatar
It actually comes out from inside the car. Pull the panel out with the treadlevac attached after the lines have been disconnected and then remove the plate after it has been removed.
Old Nov 20, 2019 | 06:18 AM
69Chrgr's Avatar
We disconnected the the lines, unbolted from panel and dropped out of bottom of car, reinstalled same way. Didn't wan't to take any chances of any fluid getting on carpet or inside of car. But maybe it's easier doing it redoldsman's way.
Old Nov 20, 2019 | 06:48 AM
redoldsman's Avatar
Whatever works. I pulled the carpet back when I removed mine. Taking it our from inside is also a 1 person job. The main thing is that you got it done.
Old Nov 20, 2019 | 05:09 PM
Some of the difference between the 55 and 56 brake system would be the location and design of the vacuum tank with the difference being that the 56 vacuum tank is under the hood passenger side and the tank on the 55 is under the left hand frame rail. There are quite a few small differences but using only one could cost you to take a wild goose chase ordering parts.... Tedd
DFitz
Aug 28, 2013 07:05 PM
Olds Dad
Sep 11, 2012 07:45 PM
Mr. SS & AFX
Mar 28, 2012 09:55 AM
tarps3
Brakes/Hydraulic Systems
Jun 29, 2008 05:00 AM
<marksz71>
Oct 20, 2006 07:14 PM
