1958 371 Oil Pump
Old Mar 25, 2023 | 10:58 AM
Wally's Avatar
1958 371 Oil Pump
As part of the rebuild of the 371, I decided to tear down the oil pump. I thought I would investigate what displacement it was.
After some calculations I came up with 2 cubic inch per revolution. If we assume an idle speed of 750 RPM then since the distributor turns half the speed of the engine, a 2 cubic inch gear pump will produce 750 cubic inches per minute. Since there are 231 cubic inches per gallon that amounts to a flow of over 3 GPM. That also means that the pump would be producing a flow of over 20 GPM at 5000 RPM.
Now you know more about the oil pump and flow through the engine you probably wanted to.
Old Mar 30, 2023 | 06:38 PM
BobsFiftyEight's Avatar
Tool Freek
You are correct, to much information for me on a oil pump
Bob
Gene kerr
Oct 26, 2022 06:06 AM
New2oldsw30
Sep 17, 2022 10:57 PM
grannys442
Feb 12, 2021 11:22 AM
Rocketbrian
Jan 2, 2015 09:45 AM
Sampson
Apr 4, 2013 09:47 AM
