1955 oil pressure line
Old Mar 10, 2023 | 07:09 AM
ub2693v's Avatar
I damaged my oil pressure line to the gauge when putting the body back on the frame, does anyone know what type of flare tool I would use to make a new line? looks like it's 1/8" line but the flare on the ends looks different than anything I've seen before. There are several aftermarket oil line kits available but they are all female fittings, I couldn't find anything other than the part number in the Chassis manual for what type of thread it might be.
Old Mar 10, 2023 | 08:54 AM
redoldsman's Avatar
Proud Viet Nam Veteran
If the flair the line connects to the oil filter adapter is unusual, I would just put a new section in the line using the end connected to the adapter and use compression fittings on each end of the new section. I hope what I am suggesting makes sense.
Old Mar 10, 2023 | 10:52 AM
ub2693v's Avatar
I did that as a kid on some brake lines, the guy at the inspection station didn't think too much of it haha. I think i have enough of a straight section section for a couple compression fittings, the ends unscrewed without issue, thats probably the best bet, i don't want oil dripping on my feet if i don't get a good seal with something other than the factory connection.
Thanks!!
Old Mar 10, 2023 | 01:57 PM
redoldsman's Avatar
Those brake lines had way more PSI than the oil pressure lines.
Old Mar 13, 2023 | 08:44 PM
BobsFiftyEight's Avatar
Tool Freek
I believe this may be the male fittings with this kit you may need, Google 25-121405-1 kit, it is for a Chevy Corvette 1956
https://www.ecklerscorvette.com/1956...ck-25-121405-1
Bob
Last edited by BobsFiftyEight; Mar 13, 2023 at 08:52 PM. Reason: changed part number
Old Mar 14, 2023 | 05:13 AM
ub2693v's Avatar
YES!! that is the exact fitting. And the kit is only 10$!!
thanks!!
Old Mar 30, 2023 | 06:40 PM
Tool Freek
@ub2693v did you complete your oil gauge and line installation?
Bob
Old Mar 31, 2023 | 06:59 AM
ub2693v's Avatar
Hi Bob, i used compression fittings, eventually i will eventually replace it with the correct line but i wasn't able to start the car to test the fuel pump so i had to do a quick fix haha.
grannys442
Dec 3, 2022 01:53 PM
jklmmorr
Oct 31, 2022 05:31 PM
Mitch Greedy
Jul 19, 2016 02:43 AM
chevyguru86
Mar 18, 2016 08:19 AM
james weber
Nov 20, 2012 12:49 AM
