Oil pump dyno
Old Feb 10, 2021 | 09:20 PM
grannys442's Avatar
Oil pump dyno
Interesting stuff the guys on the Ford fe forum are fiddling with.
http://fepower.net/simplemachinesfor...p?topic=9685.0
Old Feb 10, 2021 | 10:08 PM
Bernhard's Avatar
Bernhard wrote:
Interesting topic thanks for posting.
Old Feb 11, 2021 | 04:57 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The claim has always been, a high volume oil pump steals power over a regular volume pump. It would be interesting to see if there is much difference. If 3 hp is true for a high volume pump, even if the regular pump draws 1 hp, what is 2 hp? Nothing you would ever notice and extra volume in a 7000 rpm motor is not a bad thing for sure. Good topic.
Old Feb 11, 2021 | 04:29 PM
fleming442's Avatar
I can see where the oil pump could cause excessive drag, especially if you run 20w-50 tractor oil. I've seen a lot with running aluminum rods where cold start is 75, then 15 hot idle and 40 at 6000 rpm. I run Brad Penn 10w-40 because the pressure is consistent; Lucas hot rod is a solid 2nd choice. Everything else I've tried has wild pressure fluctuations. I'm hesitant to put a stock volume pump in on this combination. I'll just have to live with bronze gears as a maintenance item.
Old Feb 11, 2021 | 06:05 PM
Interesting Bruce your combo is so particular on the oil brand. Aren't pretty much any pick up for an aftermarket pan bolt on for the high volume oil pumps?
Old Feb 12, 2021 | 09:33 AM
Bernhard's Avatar
The air induced by cavitation is an interesting topic. It will be educational watching future results and possible solutions to cavitation issue at high RPM with a wet sump.
Old Feb 12, 2021 | 11:22 AM
fleming442's Avatar
I think all the pickups are the same. I have a Moroso 7.5qt with their pickup, 6qts installed.
Sampson
Apr 4, 2013 09:47 AM
Rolds72
Mar 22, 2012 11:08 AM
Stevec
Feb 29, 2012 06:09 PM
Lawndog
Aug 11, 2011 02:27 AM
Redog
Oct 8, 2010 02:57 PM
