1956 Starfire Exhaust
Old August 31st, 2020, 11:24 AM
Raivjudge's Avatar
Anyone have any pictures of a factory exhaust setup around the back bumper especially for a 1956 Starfire with dual exhaust? I think the exhaust pipe has a 8-10 inch extension that bolts to the special tip and bracket at the end of the exhaust pipe. Is that true or does the exhaust pipe just come all the way back to that bumper bracket?
Mike
Raivjudge is offline
Old August 31st, 2020, 04:46 PM
Frank Ignachuck
ignachuck's Avatar
Hi Mike. If you're talking about the chrome tips that are attached to the bumper, like these, they are ornaments and the exhaust does not go through them.
If you're looking for the actual routing of the original exhaust, I can't help you since my dual exhaust was modified when it was replaced in 2002.
ignachuck is offline
Old August 31st, 2020, 07:04 PM
Tedd Thompson's Avatar
Just from memory but didn't the exhaust dump out short of the chrome trumpets like your replacements do. Seems as I remember that they did but I'm old and forgetful.....Tedd
Tedd Thompson is offline
Old September 1st, 2020, 12:15 AM
Killian_Mörder's Avatar
That's a common contemptable practice still used today on even luxury new cars. The real pipe curves downwards, just in front of the fakes
Killian_Mörder is offline
Old September 1st, 2020, 03:52 AM
Frank Ignachuck
ignachuck's Avatar
Here's what mine look like:
Old September 1st, 2020, 10:23 PM
In your Old's case, the pipes are 1955 issues:
Old September 2nd, 2020, 08:04 AM
Raivjudge's Avatar
Thanks guys. I wasn't sure how or even if the pipes connect to the deflector or turn down right at them. My first 50's car after years of A bodies.
Old September 2nd, 2020, 10:14 PM
solly's Avatar
So as usual I'm confused ( it's easy to do ) most of what I've seen or read indicates as Frank did that the exhaust tips are ornaments only
however the other day I saw a video which of course I can now not find where the owner of a 1956 Olds 98 went out of his way to boast that his vehicle had the factory functional dual exhaust tips and the video included a undercarriage shot of the dual exhaust hooked directly to the tips with very factory looking brackets and plate under the tips.
For what its worth Fusic does sell them and list them only as ornaments, the previous owner of my Olds had rectangular tips installed but I don't like them.
to big and distracting, some time in the near future I plan on having them replaced with smaller simple downturned chrome tips.
solly is offline
Old September 3rd, 2020, 03:17 AM
Frank Ignachuck
ignachuck's Avatar
I can assure you they were designed as ornaments, with a welded black metal plate on the back:
Having said that, remember that people have had 64 years to customize 1956 Oldsmobiles. Some nut even put LED lights in his hood ornament
Wouldn't be hard to take off the black plate and route the exhaust pipe through the chrome tip.
Old September 3rd, 2020, 07:47 AM
And if you are looking for duals on a 55 they didn't come with them. If you have them they were added later.... Tedd
Old September 3rd, 2020, 07:59 AM
Yellowstatue's Avatar
I'm one of those nuts who put LED's into my '57 fender ornaments and exhaust ornaments.
Yellowstatue is offline
Old September 3rd, 2020, 12:15 PM
Frank Ignachuck
ignachuck's Avatar
You didn't do it unless we see pictures!
Old September 3rd, 2020, 04:32 PM
Proud Viet Nam Veteran
redoldsman's Avatar
Here is what I have on my 54. They are actually repro's of mid 50's Mopar products. You may like them or hate them and that is okay. Frank you are correct in that we need pictures as proof. I couldn't find mine since they are not in my 54 Olds folder. Here is a link to the exhaust tips. These actually are deflectors that attach to the tailpipe. I like that since it keeps the exhaust off the bumper guards which will keep them from rusting.
https://shop.kustomcarparts.com/1955...aust-mopar.htm
redoldsman is offline
Old September 4th, 2020, 03:53 PM
Frank Ignachuck
ignachuck's Avatar
We may have beaten this subject to death, but I found this brochure today relating to the 1956 dual exhaust that may (or may not) be interesting. Oldsmobile Dealerships were not equipped to handle the "new" dual exhaust systems that were introduced in 1956. So Kent-Moore- a leading supplier of garage equipment- made an adapter to connect both pipes to the "exhaust eliminating systems". See where is goes under the bumper:
Old October 13th, 2020, 04:08 PM
Raivjudge's Avatar
Cool info Frank!
tgilligan
March 11th, 2020 09:31 AM
Platinum69
March 29th, 2019 03:40 PM
dmruschell
July 21st, 2015 03:42 PM
Starfire 1962
July 29th, 2011 02:47 AM
bigoldscruiser
December 4th, 2008 10:24 PM
Quick Reply: 1956 Starfire Exhaust
