1956 Package Tray Replacement
Old Mar 26, 2019 | 02:03 PM
tricordati's Avatar
Looking for information on replacing the package tray on my 1956 88 Holiday Coupe? Thanks
Old Mar 26, 2019 | 02:10 PM
TommyTheCat's Avatar
Usually Fusick has some in inventory but it looks like they dont at the moment.
I found this though
https://www.ebay.com/i/173823772254?chn=ps
https://www.ebay.com/i/132977247149?...3D132977247149
hope that helps =)
Old Mar 27, 2019 | 03:31 AM
ignachuck's Avatar
Frank Ignachuck
Two options:
1. Do you have the original package tray? Even if it's in pieces, if you can make a copy of it, Aceshigh provided excellent instructions back in 2011 on how to make your own. I made one back in 2014 for my '56 and it came out great.
https://classicoldsmobile.com/forums...-oer-junk.html
2. If you don't have the original package tray to copy, I traced mine and I can send you a copy (if I can find it.....) Let me know.
Old Mar 27, 2019 | 06:39 PM
tricordati's Avatar
Thanks. My current package tray is in good shape, it's just the previous owner installed rear speakers and I want to get rid of them. What is involved in the removal and installation of the package tray?
Old Mar 28, 2019 | 09:47 AM
ignachuck's Avatar
Frank Ignachuck
Well, as I remember, it's very simple.
First you have to remove the speakers.
Then remove the two trim pieces in the corners of the seat back, between the side windows and/or rear doors and the rear window.
Take out the seat bottom. Just lift it up. It pops out. You have to take it out to get at the seat back bolts.
Look for 63 years of neat stuff under the seat!!
Take out the seat back by removing the bolts in the lower outside corners.
The seat back should then come out by lifting up. It hangs on the package tray frame.
The package tray should then slide right out.
Old Mar 28, 2019 | 12:48 PM
tricordati's Avatar
Thanks. I'll keep the group posted.
steverw
Dec 31, 2014 02:22 PM
navvet
Dec 27, 2013 10:45 AM
tomc5
Nov 1, 2013 08:00 AM
Chumley
Feb 25, 2011 02:15 AM
1971olds350
Mar 17, 2009 04:26 PM
