Will this Fit in my car?
I am looking at a Switch pitch transmission from a 67 buick riviera it is a th400 will that fit in a 1969 cutlass s? I know I need a BOP tranny and this is a buick but seller said it may not fit. Thank You
OK, yours is currently an ST300, but not a switch pitch. You need the torque convertor, yoke, throttle linkage with the switch, and cooling lines with T400 SP.
Read this link:
http://www.442.com/oldsfaq/oftswp.htm
Read this link:
If the transmission is from a 67 Riviera, chances are it is a SP. It definitely is a BOP pattern, so it should bolt right up to the 69 Olds Cutlass. You will need to check the length vs what you already have. Also you will need to rig some sort of switch for the Switch pitch feature.
tmaleck
August 15th, 2021 08:17 AM
