Will this Fit in my car?
Old May 2, 2012 | 09:58 AM
Doomah's Avatar
I am looking at a Switch pitch transmission from a 67 buick riviera it is a th400 will that fit in a 1969 cutlass s? I know I need a BOP tranny and this is a buick but seller said it may not fit. Thank You
Old May 2, 2012 | 10:02 AM
Rickman48's Avatar
Don't think it'll be a problem, if the same length.
Old May 2, 2012 | 11:03 AM
OK, yours is currently an ST300, but not a switch pitch. You need the torque convertor, yoke, throttle linkage with the switch, and cooling lines with T400 SP.
Read this link:
http://www.442.com/oldsfaq/oftswp.htm
Old May 2, 2012 | 04:47 PM
Doomah's Avatar
Thanks for the info!
Old May 4, 2012 | 08:37 PM
d2_willys's Avatar
If the transmission is from a 67 Riviera, chances are it is a SP. It definitely is a BOP pattern, so it should bolt right up to the 69 Olds Cutlass. You will need to check the length vs what you already have. Also you will need to rig some sort of switch for the Switch pitch feature.
delta254
Feb 14, 2013 09:29 AM
GreazyAnt
Apr 11, 2012 03:02 AM
65OldsDelta88SuperRocket
Nov 21, 2011 01:25 PM
snylften
May 15, 2010 11:13 AM
