TH400 Dual Gate stays in drive
Good Morning. I just went out to move the 1970 442 over in the garage and my Hurst dual gate will not go into reverse or neutral. It seems to be stuck in drive. I moved the car a couple of days ago and it was fine. What could be the problem?
When you say "won't go into reverse", do you mean the shifter physically won't move to that position, or that the trans doesn't engage reverse with the shifter in R? If the shifter won't move, the cable has gone bad. If the trans doesn't engage, that's likely an internal problem.
Thanks Joe,
The shifter moves up and down through all gates and the tranny seemed to work fine on News Year Day when I moved the car. Today I got it started, backed it out of the garage and moved it over to the other side. When I went to put it in park, nothing happened. It was still in drive. I had to just turn off the engine. Tom
Thanks Joe,
ah64pilot
May 29, 2012 03:04 AM
