TH350 to TH400
Old June 3rd, 2019, 09:06 AM
72GoldOlds350's Avatar
Question TH350 to TH400
Hello,
I currently have a TH350 in my 1972 Cutlass, and Mark R just built me a stout SBO 350, and I'm installing a TH400 to go with it. So far, I've only purchased the new trans mount and new parking brake cables, but is there anything else I'd need to make the installation work? Any other oem-style cabling, brackets, etc.?
Much appreciated!
72GoldOlds350 is offline
Old June 3rd, 2019, 09:18 AM
The transmission yoke is different, the TH400 uses an electric kick down solenoid. I think all the 68-72 A-body cars have the wiring already under the dash, you need the switch, mounting bracket, and add the wire to the existing engine harness under hood. The dipstick and trans fill tubes are different, the vacuum modulator is in a different location. That’s all the differences I can think of.
matt69olds is offline
Old June 3rd, 2019, 10:00 AM
Olds Fanatic
69 Hurst's Avatar
Its been a while since I did this conversion myself. If I remember correctly, the "pad" on the cross member for the trans mount needs to be cut off the front side and welded to the back side if going from a TH350 to TH400. This will not be an issue if you are replacing your existing cross member with one from a TH400 car.
69 Hurst is offline
Old June 3rd, 2019, 10:21 AM
A drive shaft and a new yoke. The xmember is the same it just needs to be moved back a couple of holes.
oldcutlass is online now
Old June 3rd, 2019, 10:56 AM
Thanks, everyone! Yes, I have a new driveshalf being made once the engine and trans is installed.
So far I have:
-kick down solenoid
-switch
-mounting bracket
Old June 3rd, 2019, 05:06 PM
Olds Fanatic
69 Hurst's Avatar
Ah, I did the conversion on a '78 Trans Am. We did not have the option of using other holes as there weren't any.
69 Hurst is offline
Old June 7th, 2019, 10:10 AM
Hello all,
below is a screenshot of the itemized parts list - I think I have them all. Let me know if I'm forgetting anything!
Old June 7th, 2019, 11:14 AM
svnt442's Avatar
Originally Posted by 72GoldOlds350
Hello all,
You don't need to do anything with your crossmember except to move it back. They are the same for all transmissions in the 68-72 A bodies.
svnt442 is offline
Old June 7th, 2019, 12:22 PM
delete
droptopron's Avatar
On my 70 I had to cut the tab off the gas pedal that the Turbo 350 kickdown cable connected to. It interfered with the switch. On my car the wiring was already part of the harness. I just hooked it up.
http://www.buickperformanceclub.com/conversi.htm
droptopron is offline
Old June 7th, 2019, 06:26 PM
I've heard this before, but then others (see below) say they had to alter the crossmember. I guess I could always find out and order the part if I indeed need it.
Also, even if the stock crossmember does work, considering the new amounts of power the engine is going to produce, is that aftermarket crossmember any stronger?
Thanks for the link! I wonder if that is the same for Olds.
Old June 7th, 2019, 07:06 PM
You can modify your old modulator line to work on the T400 and as stated above you just need to move your current cross member back a bit.
Old June 7th, 2019, 11:22 PM
Is the aftermarket crossmember any stronger that stock?
Old June 8th, 2019, 03:40 AM
I’m sure the boxed crossmember is stronger than stock, they are also much heavier. The G-Force crossmember I used in my 87 442 years ago was a beast.
Old June 8th, 2019, 09:45 AM
svnt442's Avatar
You're not putting down enough power to worry about it. You'll crack the transmission case before you hurt the crossmember.
svnt442 is offline
Old June 8th, 2019, 05:40 PM
I don’t think the trans crossmember is ever really under serious stress. I’m guessing chassis flex would be a issue long before the trans crossmember causes problems
Old June 13th, 2019, 09:13 AM
Any other parts I may need that are not listen on the parts list I supplied? Just hope I'm not missing anything.
Old June 22nd, 2019, 09:12 PM
I'll take that as a negative. I do appreciate all the help, everyone! Love the community on this site. I'll keep everyone posted if I run into anything specific or if there's any updates.
Old June 23rd, 2019, 03:30 AM
There is no difference in factory crossmembers from TH350 to TH400. Use your old one. And yes, the accelerator pedal for a TH350 needs to have the tab cut off.
joe_padavano is online now
Bassemaa93
July 19th, 2016 08:02 AM
70cutty
May 18th, 2016 10:08 AM
1968ragtop
July 9th, 2011 07:33 PM
texasred
March 14th, 2011 07:42 AM
troys2222
May 24th, 2007 10:18 AM
Quick Reply: TH350 to TH400
