TH350 no 2-3 shift
TH350 no 2-3 shift
So, the car had third gear last fall, but not this spring. I thought it would be the vacuum modulator, but the books say if you have 1-2, it's not the modulator. The TV cable seems just fine, so the next on the list is a stuck 2-3 valve.
Can any one tell me if I will be able to get a pick at the 2-3 shift valve with the pan off or does the whole assembly need to be pulled out?
oldzy
December 10th, 2010 02:38 PM
