TH 350 fluid problem
Old Nov 4, 2008 | 06:44 AM
thatguy32567's Avatar
Unhappy TH 350 fluid problem
So my transmission for my 71 cutlass is acting very strange. Its been dumping out the fluid i put in it the past 3 times all within a week. I was wondering if there was anything that would prevent this? It doesnt look like its leaking but its coming out somehow. Maybe there a filter or screen in the transmission that pushing the fluid out? Please I need some advice to fix my car.
Old Nov 4, 2008 | 06:48 AM
Double check that your pan is tight and the gasket is in good condition. Have you service the transmission filter recently?
Old Nov 4, 2008 | 08:12 AM
No its been sitting in my garage for about 2 years and i finally just got it up and running. How much would you say it would cost to get that fixed and/or is it easy to do yourself?
Old Nov 4, 2008 | 09:25 AM
olds68's Avatar
Check the grommet/O ring where the fill tube goes into the tranny. That could easily dry out over time. I had a similar situation a year ago. After I pulled the fill tube out and put a rubber O ring on the end, my problem was fixed.
Old Nov 4, 2008 | 10:45 AM
Replacing the transmission filter and gasket is easy. It costs less than $30.
Old Nov 5, 2008 | 04:17 PM
rocwal
Guest
Posts: n/a
TH350 fluid problem
Hi . I had a similar problem with my 68 olds 98 with a TH400 ,but mine was leaking onto the floor of garage it was completly rebuilt when i did a nuts and bolts frame off restoration ,I would check it for the source of leak couldnt find it ,finialy replaced the modulator valve solved the problem ,only thing i can think is the vacum was sucking or pushing the fluid out .
rocwal
Dan B
Old Nov 6, 2008 | 10:14 AM
rocwal
Dan B
Exactly same with mine. I cant fine the source of the leak it seems like its pushing it out of the fill tube for some reason. How would i fix that?
Old Nov 6, 2008 | 10:15 AM
well how do I get to the filter?
Old Nov 6, 2008 | 01:39 PM
All you have to do is drop the transmission pan. The filter is either pressend into the body of the transmission, or it might be held on by a bolt.
Pookster6
Oct 31, 2011 11:52 AM
cfair
Brakes/Hydraulic Systems
Jun 8, 2009 12:37 AM
Pete77
Drivetrain/Differentials
Jul 22, 2006 12:12 AM
Pete77
May 15, 2006 05:37 PM
