Muncie 4sp.
Old October 2nd, 2016, 06:18 AM
Bfg
Bfg's Avatar
Muncie 4sp.
Getting ready to rebuild my Muncie 4 sp. Who is a reputable parts supplier these days?
Bfg is offline
Old October 2nd, 2016, 06:50 AM
Old School Olds
tru-blue 442's Avatar
You may check with joesw31, he knows these transmissions inside and out.
tru-blue 442 is online now
Old October 2nd, 2016, 11:52 AM
therobski's Avatar
Cajun John in Texas has been working on these for over 40 years. Just got the M21 back from him for my 67. Excellent work fair price. he may sell you parts too.
http://www.kajunjon.com/
therobski is online now
Old October 2nd, 2016, 04:26 PM
seansolds's Avatar
I rebuilt mine over last winter. Not a repair, I'm talking everything off the main shaft full inspection. I ordered from this company parts came correct. You will need a press and probably may want to order the front shaft nut wrench, its design is only for the main shaft nut purpose. I replaced all bearings and cluster shaft too. Order the proper rebuild gear assembly grease if you don't have any. You also should have Muncie rebuild book but if you don't you can look on line. Also take a photo of your synchro's on the main shaft before disassembly it will help you with reassembly. Mine works beautifully and it's easy to do if you have some mechanical abilities and some patience! You will save some money and you can always say you did it yourself. Here is the link.
http://www.thegearbox.org/home.html
Good luck.
Sean
seansolds is offline
Old October 2nd, 2016, 07:44 PM
http://www.manchestermuncies.com/new...4-speed-parts/
1969w3155 is offline
mobileW-30
February 1st, 2013 01:41 PM
junior supercar
November 30th, 2012 09:14 AM
tflem81
June 23rd, 2012 08:11 PM
HILTS
April 22nd, 2009 06:11 AM
DaLump
February 14th, 2008 06:25 PM
Quick Reply: Muncie 4sp.
