ATF Fluid Level
Old May 5th, 2018, 03:49 PM
Zacc's Avatar
ATF Fluid Level
Got a 72 Cutlass 455 with TH400 trans. if you check fluid level hot in park , car running level is at add mark. When coolds down, it reads full. No smell to fluid and totally clear/clean. Trans shifts fine. Confused if I should add pint of fluid. comments pls.
Zacc
Zacc is offline
Old May 5th, 2018, 04:38 PM
Olds Fever
CRUZN 66's Avatar
If the fluid level is not full while running in park, add fluid to the full mark... The reason the fluid level reads full when not running and cooled down is because the fluid from the converter and other areas of the trans drains back into the case since the case is not full as specified while running in park...
CRUZN 66 is offline
Old May 5th, 2018, 05:18 PM
Add a pint. Should be checked fully warmed up.
oldcutlass is offline
Old May 5th, 2018, 05:59 PM
Zacc's Avatar
Thanks guys, they always stress "do not overfill" so I figured I'd check. You guys are A-OK!
Zacc
Zacc is offline
Old May 5th, 2018, 07:35 PM
W30
truckman5000's Avatar
What happens if overfild
truckman5000 is offline
Old May 5th, 2018, 08:27 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Foaming which isn't great but much better than really low fluid and only sucking air.
olds 307 and 403 is offline
1969cutlazz
May 8th, 2011 03:04 AM
1973olds98
October 24th, 2010 06:42 PM
craftsman1956
September 2nd, 2010 07:46 AM
cfair
Brakes/Hydraulic Systems
June 8th, 2009 12:37 AM
asadebo
Alero
May 3rd, 2009 08:35 PM
Quick Reply: ATF Fluid Level
