ATF Fluid Level
Old May 5, 2018 | 03:49 PM
Zacc's Avatar
ATF Fluid Level
Got a 72 Cutlass 455 with TH400 trans. if you check fluid level hot in park , car running level is at add mark. When coolds down, it reads full. No smell to fluid and totally clear/clean. Trans shifts fine. Confused if I should add pint of fluid. comments pls.
Zacc
Old May 5, 2018 | 04:38 PM
CRUZN 66's Avatar
Olds Fever
If the fluid level is not full while running in park, add fluid to the full mark... The reason the fluid level reads full when not running and cooled down is because the fluid from the converter and other areas of the trans drains back into the case since the case is not full as specified while running in park...
Old May 5, 2018 | 05:18 PM
Add a pint. Should be checked fully warmed up.
Old May 5, 2018 | 05:59 PM
Zacc's Avatar
Thanks guys, they always stress "do not overfill" so I figured I'd check. You guys are A-OK!
Zacc
Old May 5, 2018 | 07:35 PM
truckman5000's Avatar
W30
What happens if overfild
Old May 5, 2018 | 08:27 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Foaming which isn't great but much better than really low fluid and only sucking air.
1969cutlazz
May 8, 2011 03:04 AM
1973olds98
Oct 24, 2010 06:42 PM
craftsman1956
Sep 2, 2010 07:46 AM
cfair
Brakes/Hydraulic Systems
Jun 8, 2009 12:37 AM
asadebo
Alero
May 3, 2009 08:35 PM
