64 Cutlass trans woes
Old August 27th, 2018, 04:27 PM
Bobbity's Avatar
I recently acquired a '64 Cutlass, 330, Jetaway trans. I toasted the trans towing it, so what reasonable options do I have? I can't afford a hot rod transmission or a high zoot rebuild, but are there more economical ways to get it back on the road? TH350, rebuild, a pony....I'm pretty capable doing my own wrenching, but I won't rebuild it unless I can con my kid into doing it...
Bobbity is offline
Old August 27th, 2018, 04:54 PM
I fixed your thread title. The TH350 is as close to a direct bolt-in as you can get. The 2.52 first gear will make a noticeable difference off the line also. The hardest part of this swap is cobbling up a kickdown cable, as the original Jetaway used an electric kickdown. Aftermarket cable kits will solve this problem. Everything else bolts right in, though of course your two speed shifter won't show all three forward gears.
joe_padavano is online now
Old August 27th, 2018, 05:08 PM
Bobbity's Avatar
Way cool. So the bell housing pattern matches the 330? Would this be any BOP 350 or Olds/model/year/engine specific?
Bobbity is offline
Old August 27th, 2018, 05:09 PM
Any short tail BOP TH350 works.
Old August 27th, 2018, 05:24 PM
Bobbity's Avatar
Excellent news, thank you!
Bobbity is offline
Old August 27th, 2018, 05:54 PM
Rocket Renegade!
I put a TH350 in my '64 Cutlass years ago. Really woke that 330 up. A big improvement -- couldn't recommend it more highly. And the best thing is TH350s are cheap and plentiful nowadays because everybody wants overdrive.
BangScreech4-4-2 is online now
Old August 27th, 2018, 05:57 PM
Bobbity's Avatar
I just got off the phone with a guy who offers a complete rebuild on the BOP TH350 for $599. Might just save the day.Can I keep using the original flexplate, starter and driveline?
Bobbity is offline
Old August 28th, 2018, 07:59 AM
From post #2:
Old September 7th, 2018, 09:45 PM
Bobbity's Avatar
Picked up a th350 from a '78 Trans Am with 63,000 original miles. Guy even threw in a new torque converter. Now, to purty it up and get it put in. I know, yay me...
Bobbity is offline
Old September 23rd, 2018, 03:59 PM
Bobbity's Avatar
TH350 installed today. Haven't had a chance to drive it yet. But, for those who say it's a drop in, a few things didn't. The lip of the trans pan had to be 'relocated' partway across the left rear edge. Nobody around here makes metal cooler lines to fit. Had to get pretty creative there. The Jetaway dipstick tube doesn't speak th350, obviously. And, apparently, aftermarket dipstick tubes don't speak Cutlass. Getting one to fit properly was like a fight between eighth graders.... a whole lotta pounding went on, with very little being accomplished. But, it's in, t runs, it doesn't leak and later it'll go...
Bobbity is offline
Old September 23rd, 2018, 04:01 PM
Aftermarket dipstick tubes are designed for the Chevy bellhousing, not the BOP bellhousing. That isn't the transmission's fault. I just bend my own cooler lines.
Old September 23rd, 2018, 06:47 PM
Bobbity's Avatar
Not assigning blame, just pointing out what I learned in doing the swap. It runs ok, needs a carb most likely. But the transmission is a rousing success.
Bobbity is offline
amrcnmscle
20
December 3rd, 2020 10:55 AM
BlackDogJake
August 6th, 2018 11:57 AM
Skeetman
January 18th, 2015 12:11 PM
lass4ken
October 15th, 2014 03:27 PM
rcdynamic88
October 5th, 2013 05:20 PM
Quick Reply: 64 Cutlass trans woes
