2-speed jetaway dip stick leaking
Old Jun 1, 2016 | 12:35 AM
Haidda's Avatar
Hello,
on my ´66 f85 the dip stick is leaking. Where the tube sticks in the transmission case. The O ring is new. I read in this forum and in others, but how can I fix it. Where do I get a sleeve, a sealing or something else. Can I fix that, because the transmission is in the car.
Thank you very much
Greetings from Austria
Old Jun 1, 2016 | 07:21 AM
If it still leaks and you replaced the o-ring I suggest going to a fatter o-ring. If this doesn't work then you can try to make the dip stick tube slightly wider at the bottom. I don't see any need to remove the transmission to fix this problem.
Old Jun 1, 2016 | 08:29 AM
edzolz's Avatar
Remove the dipstick and clean the transmission opening with a good solvent cleaner. Clean up the tube with the same solvent cleaner. Install the proper size o ring and apply RTV spareingly around the ring. Re-install the tube and let the RTV set up before driving the car. Cleaning the opening in the trans is a very important step.
Old Jun 2, 2016 | 12:39 AM
Haidda's Avatar
I will try that today. Thank you
Old Jun 2, 2016 | 12:40 AM
Haidda's Avatar
Does anyone know the measurement of the tube and the measurement of the hole in the transmission case? Thank you
bulldog
Jun 8, 2010 06:37 PM
fmay50
Dec 17, 2009 10:45 PM
hamm36
Jul 15, 2008 10:23 AM
Olds luvr
Apr 22, 2008 05:20 PM
leslie
Ninety-Eight
Sep 17, 2007 06:17 PM
