Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
GM old Lubricants - specs?
Old May 10, 2024 | 01:49 PM
ourkid2000's Avatar
Good day all,
I was looking to regrease my '66 Toronado outer CV axle while I'm replacing the boot. The CSM calls for GM lubricant # 1050530 but I don't see anything in there that tells me what it actually is. Does anyone have an old spec sheet for these old vintage greases? I assume it's some moly fortified lithium grease.
Old May 10, 2024 | 01:56 PM
I'd use wheel bearing grease available at your local auto parts store. I'm sure there are specific ways to measure wheel bearing grease, but a modern version will probably be far superior to anything available years ago. Plus, you'd be hard pressed to justify spending extra on NOS fluids for a concours restoration.
Old May 10, 2024 | 01:59 PM
I would think whatever grease they use in modern CV joints would be adequate.
Old May 10, 2024 | 02:11 PM
ourkid2000's Avatar
Oh I'm not doing anything like that. I just want to buy something that is along the same lines of what was in there originally......a modern version so to speak.
Old May 10, 2024 | 03:11 PM
Sugar Bear's Avatar
NAPA sells specific CV joint grease, Sta-Lube makes one and RedLine CV2 specifically says it is for CV joints, GKN Loebro makes a specific CV grease.
Old May 11, 2024 | 06:15 AM
Don't overthink this. Get a CV joint grease and call it good. The parts do not need, nor will care, about the specific molecular composition.
Old May 11, 2024 | 08:53 AM
ourkid2000's Avatar
That's just it though. You can't buy something called "CV joint grease" off the shelf here, you can only get that stuff in a package as part of a "Boot Kit" that costs......you guessed it, well over 50 bucks here. I just need some grease. Something that will work in a CV joint and I don't want to pay 50 bucks for it on principle. So I'm not overthinking it, just trying to use some common sense.
Old May 11, 2024 | 08:59 AM
Sugar Bear's Avatar
Can you mail order one of the brands I listed in post #5?
Old May 11, 2024 | 09:30 AM
ourkid2000's Avatar
Yep, almost 40 bucks though
Old May 11, 2024 | 09:32 AM
Sugar Bear's Avatar
Wow, why so much? Exchange rates?
Old May 11, 2024 | 09:54 AM
ourkid2000's Avatar
No idea. Canada gets the shaft on lots of things like this. Anyway, I'm not gonna stress too much on this LOL. It's getting some 3% moly lithium based grease. I'm sure it will be fine.
Old May 11, 2024 | 09:59 AM
Sugar Bear's Avatar
CRC Sta-Lube is $11 US on Amazon. I agree it will likely be fine.
70GT
Jun 25, 2023 08:09 PM
scrappie
Sep 22, 2020 07:57 PM
68442
May 23, 2019 08:56 AM
Railguy
Jul 17, 2012 01:26 PM
flatoz
Mar 5, 2009 07:37 PM
