Whats the best bearing grease?
Old Nov 12, 2019 | 04:51 AM
scrappie's Avatar
What kind of grease to you guys recommend for re-packing front wheel bearings on 70 442?
Whats the benefit of Moly grease?
Old Nov 12, 2019 | 05:39 AM
I just buy a tub of wheel bearing grease at the parts store.
Old Nov 12, 2019 | 06:04 AM
scrappie's Avatar
OK thx Joe. Thats what I was planning but didn't know if one type (or color) is better than other
Old Nov 12, 2019 | 06:10 AM
I've never had an issue with generic wheel bearing grease. Frankly, I suspect that properly packing the bearings is far more important than the type of grease, especially on older cars that aren't highly stressed. I took high school auto shop waaaaay back, just after the Earth cooled, and they taught us to force the grease into the bearings by pressing the bearing against a glob of grease in the palm of our hand.
Old Nov 12, 2019 | 06:37 AM
I always buy disc brake/hi temp grease as it can be used with either.
Old Nov 12, 2019 | 07:38 AM
I suspect that these days you'll be hard pressed to find a tub of wheel bearing grease that isn't disc brake/high temp.
Old Nov 12, 2019 | 10:20 PM
Just the way that I learned to do it, so many years ago.
Old Nov 13, 2019 | 05:02 AM
...just after the Earth cooled...they taught us to force the grease into the bearings by pressing the bearing against a glob of grease in the palm of our hand.
^^x3^^ Except the Earth had not cooled completely when I was taught the same manner of packing grease into bearings.
Old Nov 13, 2019 | 05:20 AM
exotec's Avatar
Olds Omega
....., and they taught us to force the grease into the bearings by pressing the bearing against a glob of grease in the palm of our hand.
and I was wondering a few days ago what my brother was doing!
Old Nov 13, 2019 | 05:25 AM
exotec's Avatar
Olds Omega
May I add a question here? what are you going to use for ball joints? same or something different?
Old Nov 13, 2019 | 05:47 AM
Just a generic grease that comes in a tube for a grease gun.
Old Nov 13, 2019 | 06:01 AM
exotec's Avatar
Olds Omega
Thank you Eric!
Old Nov 13, 2019 | 07:28 AM
Lonnies Performance's Avatar
The only caution is that certain types of greases should not be mixed.
There are, to name a few, calcuim, lithium, moly, & silicone based greases.
Some are not compatible with each other so it is preferred when repacking to thoroughly clean out the old & install new instead of mixing the 2.
Old Nov 26, 2019 | 10:48 AM
71OldscutlassS's Avatar
I just use common ball bearing grease for the wheel bearings and ball joints on the suspension and steering linkage.
Greetings
Old Sep 22, 2020 | 07:57 PM
Dja642@aol.com's Avatar
I still have the container of Quaker State wheel bearing grease purchased when my 68 Cutlass was new. It has a “firmness” to it compared to a container of Castro’s wheel bearing grease which looks like what you would put in a grease gun. It’s possible the QS goes back to my 56 Super 88. It was a few years ago.
cdrod
Nov 8, 2019 05:01 AM
mitchy
Brakes/Hydraulic Systems
Oct 5, 2018 10:11 AM
Captain_Fish
Drivetrain/Differentials
Oct 3, 2010 12:10 PM
Classiccarjohn
May 18, 2010 09:49 AM
dan2286
Mar 16, 2009 11:45 AM
