Rear Wheel Bearing Part Number
Old May 21, 2019 | 04:19 PM
68442's Avatar
1970 Cutlass rear axle/wheel bearing. Question is. What is the GM/OEM part number for this bearing/retainer? Does It carry A RW507** part number?? I know The Timken SET9 is the aftermarket number
Old May 21, 2019 | 04:25 PM
The RW507C is the sealed bearing for the early (67-69) O-Type. The 1970 used an open bearing that is oiled by the diff lube. The part numbers I collected off my 1970 showed a Bower RU1578NNV for the axle bearing. Not sure if that was the factory bearing or a replacement from back in the day (been too many years for me to recall the details).
Old May 22, 2019 | 04:04 AM
68442's Avatar
The Only info i find is the RW507 was the bearing carried across the GM board with just a suffix letter or letters to designate it's specific application up to 69. For example "CR" was as you stated (67-69) and "GR" was for the Vista (67-69) Etc. That number was used on other GM cars as well with different letter codes. Was not sure if it carried into 70 but i have not seen it as of yet. The Bower is an aftermarket supplier.
Need to find the OEM Part number.
Old May 22, 2019 | 06:23 PM
Yellowstatue's Avatar
GM # 7451959 roller type. Sup. # 9795781. Try that.
Old May 23, 2019 | 04:49 AM
68442's Avatar
Thanks Guys for the Help
Might you also know the OEM/GM Seal #???
Old May 23, 2019 | 08:56 AM
The number I have is 712146, which is the same for the 71-up 8.5" 10 bolt rears.
ostie13
May 31, 2014 06:39 AM
rustyroger
Dec 8, 2013 07:14 AM
Kolby66
Drivetrain/Differentials
Jul 14, 2013 09:19 AM
Classiccarjohn
May 18, 2010 09:49 AM
flatoz
Mar 5, 2009 07:37 PM
