Bearings
Old May 31, 2014 | 05:21 AM
ostie13's Avatar
Bearings
I have a question I hope someone can answer.The part number I have for the Inner Front Bearings for my 71 Toronado is LM 104949E and LM 104911d2.I found a set with the Delco part number 907677.My question is are those the outer bearings or maybe the rear bearings? Where do the fit. Does anyone know ?
Old May 31, 2014 | 06:01 AM
nicks1966's Avatar
I looked up that delco bearing number and it cross to a Timken rw508br.
it's listed as a automatic transmission final drive bearing but was also used a rear wheel bearing from 65 to 71 on some models.
Old May 31, 2014 | 06:19 AM
Octania's Avatar
Do you have a group number? If so a paper manual PN search could be done.
Try googling the PN
try PN search at e.g. rockauto.com
Old May 31, 2014 | 06:39 AM
ostie13's Avatar
I found a group Number 5855. Its on ebay right now.I want to bid on it but want to know if it will fit first.Its under bayareabargins 4377 on Ebay
oldzy
Drivetrain/Differentials
Sep 14, 2010 05:40 AM
olds1968
Apr 18, 2008 08:39 AM
Andrew240
Dec 22, 2007 01:54 PM
olds350
Dec 21, 2006 05:11 PM
