Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
68 Air deflector Partial Part # 535-LH
Old Aug 2, 2018 | 09:45 AM
vistacruiser1971's Avatar
Olds Collector
Hello: I have a 68 Cutlass/Vista air deflector across the width of the core support under the car. There is a smaller air deflector attached attached on the driver side and i have a partial part number 535-LH. There are several what looks like leading zeros and I can't read the first digit(s). It sure looks like there was a pass side at one time. I don't recall seeing these parts before. Were they used 68-72 or only part of those years? Anyone know the complete part number and its value? Regards, Trent in Los Angeles
Old Aug 3, 2018 | 03:43 PM
rcorrigan5's Avatar
Randy C.
I'm pretty sure it's a '68-only part. I have both a '68 and '69 4-4-2 and the deflectors are different for each of those years.
Randy C.
Old Aug 3, 2018 | 04:56 PM
Olds Collector
Smile 68 Air Deflector
Hi Randy: Is this a great site or what? Thank you very much. I suspected some problem here with this part. Nothing like it is reproed. I don't even see a repro'ed large deflector that hangs below the core support the width of the car. Were yours factory installed? Did you ever see one or a pair for sale and what was the list price? Is it possible for you to read the complete part number? You don't have to remove it from the car. It is on the small flat edge that faces the ground. Should be easy to see from under the car. Thank you in advance for any other help you can. Regards, Trent in Los Angeles
Old Aug 3, 2018 | 07:16 PM
rcorrigan5's Avatar
Randy C.
Yes, mine was factory-installed - it's a Lansing car. The air dam/deflector actually consists of 3 pieces - the center piece, part number 398171, and the two side pieces (driver side part number 400535-LH and passenger side part number 400534-RH) which are stapled to the center piece. The complete set-up is hard to find as it is a one-year-only part and I'm pretty sure no one reproduces them. There was a used one in pretty good condition for sale on this site not to long ago and, as I recall, it went fast. I don't remember the asking price. I would place an ad in the "parts wanted" section of this site and see what happens.
This is a great site! I started restoring my '68 14 years ago and got lots of help just looking in here. It also helped me greatly when I did my '69 from about 2014 to 2016.
Randy C.
Old Aug 4, 2018 | 10:20 AM
Olds Collector
68 Air Deflector
Hi Randy: Thank you so much for your help. Nice to have a record of the three part numbers. You were right, back in June of this year someone advertised the three pieces for $75 and it went fast. There is also more information of those parts from older posts. It is great to be able to help each other out like this. Thank you again Randy. Regards, Trent in Los Angeles
WTony
Dec 27, 2017 01:58 PM
tru-blue 442
Feb 26, 2015 09:59 AM
Hotrodmax
Jul 7, 2012 01:30 PM
mmurphy77
Hurst/Olds
May 21, 2012 11:31 AM
Jamesbo
Hurst/Olds
43
Apr 21, 2009 08:42 PM
