Order of operations
Old September 30th, 2015, 10:08 PM
I'm indecisive. Or am I..
Napoleon Solo's Avatar
Order of operations
I have a novice question. I am in the process of assembling the front end components on my 64 cutlass. I have only finger tightened the crown nuts and bolts and kept everything floppy and loose until it's all together. So, now it's time to firm everything up and get cotter pins in - is there a preferred starting point and work your way through?
Napoleon Solo is offline
Old October 1st, 2015, 06:43 AM
All the steering components can be torqued and cotter pins installed with the car jacked up. The Upper and lower A frames need to be tightened with weight on the wheels or a jack stand placed under the lower control arm. There is really no sequence of events.
oldcutlass is offline
Old October 1st, 2015, 08:10 PM
Thanks Eric!
1968CutlassSupreme
January 28th, 2014 08:28 AM
64OLDSPILE
November 4th, 2012 09:17 AM
klilly80
July 6th, 2008 12:11 AM
77supreme
March 12th, 2007 04:03 PM
oldcutty
September 14th, 2006 09:20 PM
Quick Reply: Order of operations
