Order of operations
Old Sep 30, 2015 | 10:08 PM
Napoleon Solo's Avatar
I'm indecisive. Or am I..
Order of operations
I have a novice question. I am in the process of assembling the front end components on my 64 cutlass. I have only finger tightened the crown nuts and bolts and kept everything floppy and loose until it's all together. So, now it's time to firm everything up and get cotter pins in - is there a preferred starting point and work your way through?
Old Oct 1, 2015 | 06:43 AM
All the steering components can be torqued and cotter pins installed with the car jacked up. The Upper and lower A frames need to be tightened with weight on the wheels or a jack stand placed under the lower control arm. There is really no sequence of events.
Old Oct 1, 2015 | 08:10 PM
Thanks Eric!
1968CutlassSupreme
Jan 28, 2014 08:28 AM
64OLDSPILE
Nov 4, 2012 09:17 AM
klilly80
Jul 6, 2008 12:11 AM
77supreme
Mar 12, 2007 04:03 PM
oldcutty
Sep 14, 2006 09:20 PM
