Upper Control Arm (New Offset Shaft) Wrong Part??
Old Feb 5, 2024 | 06:16 PM
Tuffnut's Avatar
I’m rebuilding the passenger side upper A arm on my 75 Cutlass. Drivers side is done. The front nut is welded to the control arm shaft. I will cut it off.
The question is, I ordered a new control arm and it had an offset to it.
I want to keep the same camber, with the same shims in the front and back bolts against the frame. Will this shaft work or should cut my losses and get a straight shaft and reuse the same shims. Also I have to cut the old ball joint rivets off.
update. So I couldn’t believe I ordered an offset shaft. I went back and found my order and box in the recycling bin from rock auto and lo and behold I did order the correct part as shown in the last picture. Rock Auto shipped me an offset part shown in the second picture, what they shipped does not match the picture under mevotech description.
anyways it’s the first problem I have had with rock auto.
A new order is being processed. Will see how it works out for the 2 nd time around.
Jeff
Chuxter
Suspension & Handling
Aug 25, 2023 09:55 PM
Upstate 442
Mar 30, 2023 01:07 PM
jharsh
17
Apr 26, 2019 07:38 AM
62 Cutlass Convert
Tech Editor's Desk
Jun 11, 2015 09:15 AM
805cut
Sep 12, 2012 01:54 PM
