upper control arm bushings
how tight on your cross Shaft should new upper control arm bushings be when 1st pressed in.? Mine seem to be on the loose side just sliding them on.
Chuxter, You may already know this but...the nuts on the ends of the control arm shaft shouldn't be tightened until all of the weight is on the wheels. If tightened before the torsion on the rubber will destroy the bushing in a hurry.
62 Cutlass Convert
Tech Editor's Desk
Jun 11, 2015 09:15 AM
