upper control arm bushings
Old Aug 25, 2023 | 12:31 PM
Chuxter's Avatar
1970 Cutlass Supreme
how tight on your cross Shaft should new upper control arm bushings be when 1st pressed in.? Mine seem to be on the loose side just sliding them on.
Old Aug 25, 2023 | 03:33 PM
The bushings are loose on the shaft. The clamp nut and washer locks them in place.
Old Aug 25, 2023 | 03:52 PM
Chuxter's Avatar
Thanks Joe I appreciate the help
Old Aug 25, 2023 | 05:09 PM
Note the serrations on the inner sleeve that hold the bushing in place against the step on the shaft when you torque the nut.
Old Aug 25, 2023 | 08:23 PM
Sugar Bear's Avatar
Chuxter, You may already know this but...the nuts on the ends of the control arm shaft shouldn't be tightened until all of the weight is on the wheels. If tightened before the torsion on the rubber will destroy the bushing in a hurry.
Old Aug 25, 2023 | 09:55 PM
Ensure that the cross shafts are not worn, the bushings should fit snug.
dennis_30281
Jan 4, 2018 03:44 PM
62 Cutlass Convert
Tech Editor's Desk
Jun 11, 2015 09:15 AM
1969cutlass4d
Feb 26, 2015 08:56 PM
johnnyjaws
Suspension & Handling
Jun 16, 2014 08:48 PM
costpenn
18
Apr 20, 2012 03:04 PM
