upper control arm bushings
Old August 25th, 2023, 12:31 PM
Chuxter's Avatar
how tight on your cross Shaft should new upper control arm bushings be when 1st pressed in.? Mine seem to be on the loose side just sliding them on.
Chuxter is offline
Old August 25th, 2023, 03:33 PM
The bushings are loose on the shaft. The clamp nut and washer locks them in place.
joe_padavano is offline
Old August 25th, 2023, 03:52 PM
Chuxter's Avatar
Thanks Joe I appreciate the help
Chuxter is offline
Old August 25th, 2023, 05:09 PM
Note the serrations on the inner sleeve that hold the bushing in place against the step on the shaft when you torque the nut.
Old August 25th, 2023, 08:23 PM
Sugar Bear's Avatar
Chuxter, You may already know this but...the nuts on the ends of the control arm shaft shouldn't be tightened until all of the weight is on the wheels. If tightened before the torsion on the rubber will destroy the bushing in a hurry.
Sugar Bear is offline
Old August 25th, 2023, 09:55 PM
Ensure that the cross shafts are not worn, the bushings should fit snug.
oldcutlass is offline
dennis_30281
January 4th, 2018 03:44 PM
62 Cutlass Convert
Tech Editor's Desk
June 11th, 2015 09:15 AM
1969cutlass4d
February 26th, 2015 08:56 PM
johnnyjaws
Suspension & Handling
June 16th, 2014 08:48 PM
costpenn
18
April 20th, 2012 03:04 PM
Quick Reply: upper control arm bushings
