Front shocks lower captive nuts/bolts
Old February 17th, 2024, 07:06 PM
rfpowerdude's Avatar
Since I was only able to get two out of four off without breaking them, I had to cut the other two off.
Does anyone make new replacements? Getting to the top side with random nuts is a PITA, captive ones like the originals would be better.
rfpowerdude is offline
Old February 17th, 2024, 07:15 PM
Everybody sells them. I got my last set on ebay. Also Amazon and most of the repro houses as well as AMK fasteners.
https://www.ebay.com/itm/19268980136...ylTkokpfHQlGE4
joe_padavano is online now
Old February 17th, 2024, 07:23 PM
Thx Joe, I went searching and found that OPGI has those same eBay listed ones for less including USPS shipping!
Old February 17th, 2024, 07:27 PM
You can also go to Loews, Home Depot, local bolt store, etc...
oldcutlass is online now
Old February 17th, 2024, 08:56 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Ya if you're not interested in exact OEM replacements just use a new grade 8 high-strength flanged hex head screw and serrated flange locknut with captive washer. McMaster Carr may have USA made hardware?
droldsmorland is offline
Old February 18th, 2024, 06:13 AM
The problem with that is how to get a wrench on the nut
Old February 18th, 2024, 06:31 AM
It's not a problem to tighten the bolt/nut when they are new. The problem arises when you go to take it apart down the road.
Old February 18th, 2024, 06:37 AM
That was my point. Yes, I've done this multiple times over the last five decades.
Old February 18th, 2024, 08:00 AM
Agreed its a PITA to get at for most (not me). Replacement caged nuts certainly are the better solution.
70sgeek
Suspension & Handling
April 29th, 2023 10:11 AM
Bfg
June 30th, 2019 07:43 PM
deadeyejedi
January 5th, 2016 09:58 AM
pcard
April 30th, 2014 07:16 PM
miked
March 4th, 2013 02:52 PM
Quick Reply: Front shocks lower captive nuts/bolts
