Front shocks
Old Jan 5, 2016 | 08:51 AM
deadeyejedi's Avatar
Front shocks
After a long hiatus I'm back on the 72 olds . Got the motor back in yesterday and was going to install the front shocks but ran into an issue with the length of the kyb's .even with motor in doesn't seem to have enough weight to install the shocks theyre about an inch too short .the car has new tubular upper and lower control arms and new stock 350 springs . Is it just too stiff at this point ? Should I wait until I get the front clip back on it ? I checked the numbers on the shocks and they are correct.
Old Jan 5, 2016 | 09:23 AM
RetroRanger's Avatar
72 Olds CS
did you already tighten the lca mounting bolts? They may be holding the car up you should wait for the ful car weight before tightening the lca bolts
Old Jan 5, 2016 | 09:54 AM
Old Jan 5, 2016 | 09:58 AM
I did tighten them but not torqued down yet .ill wait until I get some more wieght on the car . Got plenty of other stuff to do . Thanks
jensenracing77
Apr 24, 2012 03:00 PM
Limey
Dec 21, 2010 02:55 PM
360scamp
Nov 23, 2010 11:55 AM
marshall-no
May 8, 2010 07:18 AM
Leroy701
May 5, 2010 06:01 AM
