71 Cutlass uneven side-to-side
Old Feb 22, 2024 | 05:12 PM
Jhucks03's Avatar
Any idea what could cause my Cutlas to sit visibly higher on the right side vs the left?
Old Feb 22, 2024 | 05:59 PM
That’s the classic A-Body lean that’s been around since these cars were a few years old. Sagging springs and/or body mounts are the likely culprits.
Another possibility is someone replaced bushings and torqued then without the weight of the vehicle compressing the suspension.
Old Feb 22, 2024 | 06:12 PM
Jhucks03's Avatar
I’ve had this car for 20+ years. Haven’t ever noticed it that bad til lately. Started putting more drag race components on it recently. Solid body & driveline mounts, adjustable trailing arms in the rear with spherical bushings in the rear end, anti-roll bar etc. I lowered it back when I was in high school. Springs in the rear and spindles/springs up front.
Never paid it much attention to it until we were going to set the links for the ARB in the back, and we were like - that’s not right.
So, while we’re at it, what’s the torque on the front control arm mounting bolts? I’ll start there (loosen and retorque at ride height) and see if that has any bearing.
Old Feb 22, 2024 | 06:16 PM
Overweight driver?
(Sorry, that was waaaay too easy)
Seriously, is this a new problem or not? It the difference more on the front or the back or both? Has the suspension been apart recently? As noted, springs do sag over time, bushings wear, parts get bent. The Chassis Service Manual lists dimensions and procedure for checking ride height. I'd suggest starting there and looking for broken or damaged suspension parts first.
Old Feb 22, 2024 | 08:10 PM
tkcutlass's Avatar
make sure your springs are clocked correctly
Old Feb 23, 2024 | 03:16 AM
I missed this the first time. It is VERY easy to get the top of the front spring out of the upper pocket when installing it due to the blind installation. When this happens, that corner will end up about one inch high.
Old Feb 23, 2024 | 12:21 PM
Jhucks03's Avatar
I believe I got it figured out. Looks like the RF spring was out of position on the bottom. 180* out I think. It wasn’t turned to where the end of the spring was with the slot in the lower control arm. Will clock it and put back this evening and update.
350_rkt
Jun 7, 2019 03:45 AM
kjr442
May 26, 2014 07:31 AM
lsutigers93
Mar 24, 2014 10:21 AM
halfmoontrail
Jul 1, 2011 09:10 PM
1BLACKHARLEY
Mar 12, 2007 12:31 PM
