71 Cutlass uneven side-to-side
That’s the classic A-Body lean that’s been around since these cars were a few years old. Sagging springs and/or body mounts are the likely culprits.
Another possibility is someone replaced bushings and torqued then without the weight of the vehicle compressing the suspension.
I’ve had this car for 20+ years. Haven’t ever noticed it that bad til lately. Started putting more drag race components on it recently. Solid body & driveline mounts, adjustable trailing arms in the rear with spherical bushings in the rear end, anti-roll bar etc. I lowered it back when I was in high school. Springs in the rear and spindles/springs up front.
Never paid it much attention to it until we were going to set the links for the ARB in the back, and we were like - that’s not right.
So, while we’re at it, what’s the torque on the front control arm mounting bolts? I’ll start there (loosen and retorque at ride height) and see if that has any bearing.
(Sorry, that was waaaay too easy)
Seriously, is this a new problem or not? It the difference more on the front or the back or both? Has the suspension been apart recently? As noted, springs do sag over time, bushings wear, parts get bent. The Chassis Service Manual lists dimensions and procedure for checking ride height. I'd suggest starting there and looking for broken or damaged suspension parts first.
I believe I got it figured out. Looks like the RF spring was out of position on the bottom. 180* out I think. It wasn’t turned to where the end of the spring was with the slot in the lower control arm. Will clock it and put back this evening and update.
