warning
Old Mar 14, 2008 | 07:24 AM
tonycpe's Avatar
warning
I just recieved the part I ordered 19 days ago from gmpartsdirect. The part is going into the garbage bin. I learned my lesson.
Old Mar 14, 2008 | 08:48 AM
Oldsguy's Avatar
Past Administrator
What was the part and how was it defective? Just wondering.
Old Mar 14, 2008 | 10:25 AM
Yes, please tell us what was wrong with it!
Old Mar 14, 2008 | 12:42 PM
tonycpe's Avatar
a front cover with long dents and or creases in it were the water pump seals to it .
Old Mar 14, 2008 | 01:07 PM
Oldsguy's Avatar
Past Administrator
Well that would suck, was it used or touted as brand new? I have seen lots of them with so much corrosion there was serious doubt whether the water pump would seal or not.
Old Mar 14, 2008 | 04:13 PM
tonycpe's Avatar
It's brand new and i just checked to see if it is flat , and found it is .040 con cave across the water pump ports. and the lip on the bottom is lower , not sure how much yet, this will drop the oil pan rubber a little lower , which may or may not hurt depending on how much lower.
Old Mar 14, 2008 | 08:05 PM
Redog's Avatar
Send it back
Old Mar 14, 2008 | 08:20 PM
aliensatemybuick's Avatar
"me somebody" site member
I ordered an under-seat storage box for a Silverado pickup a few years back...was a good deal, but still a bit pricey, and I disappointed to see that it had been damaged either during shipping or before (seemed to me it was unlikely to have been damaged during shipping because it was so well packed and the outer box looked fine_. After I contacted them with my concern, they sent a nother one no questions asked. Give them a chance to make good.
Old Mar 15, 2008 | 08:58 AM
Oldsguy's Avatar
Past Administrator
So, what do you plan to do to solve your need of a front cover? Do you have another source? As I doubt you will re-order from gmpartsdirect. Me being the fabricator I tend to be (notice I didn't precede that with the word good?) I would be tempted to try and correct the concavity and lower lip on my own, but probably not a good idea.
Old Mar 15, 2008 | 09:03 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Well, since any Sbo front cover should work, it shouldn't be a problem finding another.
Old Mar 15, 2008 | 02:59 PM
Actually, any 64-90 Olds big or small block front cover (except 64 394) will work. As for the one you bought being new, since you got it from gmpartsdirect I suspect it's an N.O.S. part. The last one was stamped by the factory 17 years ago, so this one is at least that old. It's unfortunate that the one you received was damaged, but things do happen. I agree that you should give them a chance to make good.
csstrux
Dec 16, 2015 09:12 AM
w-30dreamin
Jan 23, 2010 01:55 PM
Dan Wirth
Aurora
Sep 18, 2009 06:56 AM
dagr8tim
Jun 2, 2008 12:14 PM
dyscookn
Mar 19, 2008 09:33 PM
