olds 307 timing marks
Old August 15th, 2012, 07:41 PM
83lesabre's Avatar
Hey everyone,
Recently I replaced the ti$ing chain in my 83 lesabre's 307. It went well. +,ly problem is I found the owner before me had also done it, but neglected to bolt the timing marker tab back to the front of the engine, so I cannot time the engine.. I have checked junkyards, and online and no luck. Does anyone know where I could find the part? Thanks!
83lesabre is offline
Old August 15th, 2012, 07:58 PM
Redog's Avatar
http://compare.ebay.com/like/3901548...Types&var=sbar
This will work
Redog is offline
Old August 15th, 2012, 08:06 PM
Where are you located?
Allan R is offline
Old August 15th, 2012, 10:03 PM
Octania's Avatar
You might want to avoid that vendor that redog linked to
I have lots of used ones if that will do for you.
517.449.0432 text or call
Octania is offline
Old April 22nd, 2016, 08:08 PM
Gearhead in training
Northern Custom Cruiser's Avatar
I believe i have the same problem, i know this post is from forever ago but would you have any extras?
Northern Custom Cruiser is offline
Old April 23rd, 2016, 08:35 AM
Octania's Avatar
I do have a box of extras
Balancer OD has two options, therefor two types of plastic timing tab.
text? 517.four 49.oh 432
Octania is offline
Old April 30th, 2016, 09:18 AM
Octania's Avatar
Here is the difference between the plastic tab for larger OD harmonic damper balancer and smaller OD balancer w/o harmonic damper ring.
These plastic tabs were used in the smogger era, not sure exactly when they started, probably around the semi-metric era, 1977 or so, thru the end of the iron block Olds V8.
Not they are both supposed to have the metal washer insert at the top hole, but the "large" unit shown has a common flaw- the insert has come out.
Octania is offline
Carshinebob
September 11th, 2013 04:06 AM
losthillbilly73
December 23rd, 2011 01:32 PM
iam2fast4u86
February 4th, 2009 06:31 AM
cisco88
October 17th, 2008 07:12 PM
MIRADAMANia
April 22nd, 2008 01:00 AM
Quick Reply: olds 307 timing marks
