olds 307 timing marks
Old Aug 15, 2012 | 07:41 PM
83lesabre's Avatar
Hey everyone,
Recently I replaced the ti$ing chain in my 83 lesabre's 307. It went well. +,ly problem is I found the owner before me had also done it, but neglected to bolt the timing marker tab back to the front of the engine, so I cannot time the engine.. I have checked junkyards, and online and no luck. Does anyone know where I could find the part? Thanks!
Old Aug 15, 2012 | 07:58 PM
Redog's Avatar
http://compare.ebay.com/like/3901548...Types&var=sbar
This will work
Old Aug 15, 2012 | 08:06 PM
Where are you located?
Old Aug 15, 2012 | 10:03 PM
Octania's Avatar
You might want to avoid that vendor that redog linked to
I have lots of used ones if that will do for you.
517.449.0432 text or call
Old Apr 22, 2016 | 08:08 PM
Northern Custom Cruiser's Avatar
Gearhead in training
I believe i have the same problem, i know this post is from forever ago but would you have any extras?
Old Apr 23, 2016 | 08:35 AM
Octania's Avatar
I do have a box of extras
Balancer OD has two options, therefor two types of plastic timing tab.
text? 517.four 49.oh 432
Old Apr 30, 2016 | 09:18 AM
Octania's Avatar
Here is the difference between the plastic tab for larger OD harmonic damper balancer and smaller OD balancer w/o harmonic damper ring.
These plastic tabs were used in the smogger era, not sure exactly when they started, probably around the semi-metric era, 1977 or so, thru the end of the iron block Olds V8.
Not they are both supposed to have the metal washer insert at the top hole, but the "large" unit shown has a common flaw- the insert has come out.
Carshinebob
Sep 11, 2013 04:06 AM
losthillbilly73
Dec 23, 2011 01:32 PM
Gbobby
Feb 4, 2009 06:31 AM
cisco88
Oct 17, 2008 07:12 PM
MIRADAMANia
Apr 22, 2008 01:00 AM
