350 head bolt/stud question
Old February 7th, 2018, 02:38 PM
fasteddy's Avatar
Did a 1970 350 in a cutlass with no A/C have any head bolts that had studs on the top? My engine is away at the machinist and was taken apart before I bought the car. He says there are two head bolts with studs. With no A/C I can't see they were needed. Would they be there anyways? if so, where, the first long bolt on each side?
Thanks!
Pat
fasteddy is offline
Old February 7th, 2018, 02:43 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
A lot of Olds V8's came with factory A/C but even non A/C motors had the studs. It is a spot the ground cable is attached. It is the first short bolt in the front corners.
olds 307 and 403 is offline
The Bug Man
June 25th, 2014 01:34 PM
EightballZ
March 24th, 2014 05:03 PM
bluecab
November 8th, 2013 05:17 PM
brownbomber77
May 31st, 2013 04:20 AM
Al Graaf
September 14th, 2011 04:37 AM
Quick Reply: 350 head bolt/stud question
