Head and main bolt/stud length
Old May 15, 2013 | 09:06 AM
brownbomber77's Avatar
Does anyone have measurements on for head and main bolt lengths? I rounded off the head on a bolt, the shorter one, and am not by the car for a few more days. I want to get it ordered soon.
The long ones are 4 inches long
The 2 short ones are...?
How about main studs? I acquired a stud girdle for a 403 and it included some no name studs I don't want to use, so I was going to order a set from ARP, but don't know the length. What is the length of the main studs on a SBO?
Thanks in advance,
Dan
Old May 15, 2013 | 09:50 AM
Octania's Avatar
For a $6 usps flat rate envelope I will send you as many head bolts as you want. Studless ones, that is. Be there in 2 days.
C. Witt
517..449.Oh 432
Old May 15, 2013 | 10:15 AM
Are they ARP...? haha Crap...I forgot to mention they are ARP 1/2 inch for a '77 350. That's what I stripped. The one by the A/C evaporator, the short one... I just need the length so I can order the right one from Summit...thanks though
Old May 17, 2013 | 12:53 PM
oddball's Avatar
How in the blazes do you strip an ARP bolt?!
Call ARP - they'll hook you up. Tech guys are pretty helpful. Just tell them you need a replacement short one from that kit.
Old May 18, 2013 | 08:49 PM
Octania's Avatar
7/16 x 2.98
Head to Block, Short
Lower end positions. Non-std 11/16" Hex [wrench size]. Reduced shank 0.386 dia.
7/16 x 2.98" with
3/8 NC x 3/4 stud end
Head to Block, Short Boltstud
73-74 A-body 350, 455.
PNM says L= 3" x 3/4" stud end.
Old May 20, 2013 | 08:00 PM
Short head bolts are 3.75 underhead length, long ones are 4.25 underhead length. I ordered it. How about main bolts? I acquired some girdle that came with some hardware, but I don't trust the hardware. I was gonna replace it with ARP stuff, but can't find a length that says "for use with girdle"...or something to that effect.
Old May 28, 2013 | 12:39 PM
Called ARP and they said the main studs are
8-7/16x4"
2-1/2x4.4"
Only problem is if the girdle I'm using would need 4.5" and 4.9" respectively. I can only find 7/16x4.350 and 1/2x5.250...anyone have a stud from a girdle kit they could measure?
Old May 31, 2013 | 04:20 AM
uk79transam's Avatar
8-7/16x4"
2-1/2x4.4"
I bought a halo with crappy studs too.
Got my ARP studs to fit it from Jim @ J&S.
Just made a phone call, told him the setup and they were in the post next day.
Give him a ring, he`ll set you up
The Bug Man
Jun 25, 2014 01:34 PM
EightballZ
Mar 24, 2014 05:03 PM
bluecab
Nov 8, 2013 05:17 PM
Stevec
Aug 4, 2012 06:52 PM
Al2011
Apr 19, 2012 10:56 AM
