1964 Timing Tab
Old March 26th, 2017, 07:41 AM
ART T's Avatar
1964 Timing Tab
Installed my Fitech and trying to tune it. The timing tab has three notches, which one should I shoot for? The one all the way to the right? Thanks
ART T is offline
Old March 26th, 2017, 08:30 AM
On the picture the mark and slot on the right is 0. The center slot is 5 and the mark and slot on the left is 10* BTDC. With dwell set at 30* timing settings for a points distributor is 7.5* BTDC with vacuum advance line removed and plugged. With a non-stock distributor it depends on how much mechanical advance is built into it.
oldcutlass is online now
Old March 26th, 2017, 08:53 AM
Your picture is the 1965-up tab (which, by the way, is marked "10" and "0" if you look at that photo). The OP has a 1964. ASSUMING he has the original engine and the passenger side timing tab, it is different from the one you posted. It still is marked "0" and "10", however, with the middle being "5" degrees. Obviously set the timing to the correct advance for your application, fuel, compression, etc.
joe_padavano is offline
Old March 28th, 2017, 04:30 AM
ART T's Avatar
Thanks, all.
ART T is offline
Old March 28th, 2017, 05:52 AM
Run to Rund's Avatar
Of course, the 1964 damper has the timing mark in a different spot from the later dampers, matching the passenger side tab. Also be sure the outer ring is not starting to slip.
Run to Rund is offline
gmiles
December 27th, 2013 12:52 PM
timothypaul
October 15th, 2008 09:18 PM
griz
September 24th, 2008 05:09 PM
Ducman
November 14th, 2007 09:21 AM
Huron
July 12th, 2007 06:02 AM
Quick Reply: 1964 Timing Tab
