Vacuum Lines Clean Up
I have a olds 350 in a open wheel hot rod, wondering if there is a way to clean up the vacuum lines? I have the list advance one, trans modual, and a vacuum gauge. But it looks like there are lines going everywhere, Is there a way to clean them up since they are right in the open?
I have a 2 hookup tree or whatever you want to call it on the front of the manifold. but can i rerun these lines in the back of the motor or anything?
Intake Manifold to:
• Transmission modulator
• Brake booster
• PCV
• Distributor vacuum advance (or use vacuum from carb. port)
• A/C controls (if any)
2"-long line to choke pull-off diaphragm on carburetor.
Steel lines between automatic choke and heat exchanger in intake manifold, --OR-- use an electric choke.
That's about all I can think of.
• Brake booster
• PCV
