Vacuum Lines Clean Up
Old Jun 29, 2015 | 08:21 AM
1966g10's Avatar
I have a olds 350 in a open wheel hot rod, wondering if there is a way to clean up the vacuum lines? I have the list advance one, trans modual, and a vacuum gauge. But it looks like there are lines going everywhere, Is there a way to clean them up since they are right in the open?
I have a 2 hookup tree or whatever you want to call it on the front of the manifold. but can i rerun these lines in the back of the motor or anything?
Old Jun 29, 2015 | 08:24 AM
Year of engine?
Photos?
Old Jun 29, 2015 | 08:26 AM
You probably don't need the temp activated vacuum switch. Follow the lines and see where they go. You do need the vacuum advance, trans modulator, vacuum booster, and PCV.
Old Jun 30, 2015 | 01:06 PM
1966g10's Avatar
The motor is a 1973, all I need is the very basic. Just want to make the engine look a plain as possible.
Old Jun 30, 2015 | 01:07 PM
1966g10's Avatar
Here are some more
Old Jun 30, 2015 | 01:32 PM
Intake Manifold to:
• Transmission modulator
• Brake booster
• PCV
• Distributor vacuum advance (or use vacuum from carb. port)
• A/C controls (if any)
2"-long line to choke pull-off diaphragm on carburetor.
Steel lines between automatic choke and heat exchanger in intake manifold, --OR-- use an electric choke.
That's about all I can think of.
StarfireFox62
Sep 25, 2008 01:29 PM
#1CutlassSupreme
May 14, 2008 04:28 PM
terribleonexx88
Mar 16, 2007 12:00 PM
Chumley
Jan 3, 2007 06:00 AM
bbock
Jun 5, 2006 11:50 AM
