Open heart
Old June 2nd, 2012, 09:42 PM
805cut's Avatar
Open heart
As some of you know i had some knocking going on with my 350.. today it got really loud like bad real quick, so i decided to pull the intake manifold which ive wanted to do for a while know just curious to see what the inside of that motor looked like... i was suprised to see a pretty clean motor but a few things didnt look right.. i was hopeing to find a broken lifter or something super obvious... no luck
805cut is offline
Old June 2nd, 2012, 10:04 PM
Well, first off congratulations on getting the intake off there.
The knock or tap could be a stuck lifter, or could be more serious. Depends on the actual noise. Chances are you are going to have to delve more deeply than this to find answers. Could be anything from worn bearings to sloppy pistons, spark plug not firing.....
It is nice and clean looking in there, which usually means it received regular oil changes/mtce.
Allan R is offline
Old June 2nd, 2012, 10:07 PM
805cut's Avatar
I noticed that the lifters all shake a little bit except a few of them, could that be a sign of being stuck?
805cut is offline
Old June 2nd, 2012, 10:20 PM
I don't think that's your problem. The ones that are tight could just be under load. What I'm thinking more and more based on your initial description is you have spun bearings or a connecting rod problem. That means you'll likely have to pull the engine and rebuild. That's my opinion and I'll tell you I'm not a mechanic, but I pull wrenches on my cars and I bet I'm right.
How many miles on this block?
Allan R is offline
Old June 2nd, 2012, 10:55 PM
805cut's Avatar
To tell you the truth, i havent a clue. But im tinking your right as well... DANG i was thinking this engine would last till the 455 was built, oh well here we go again haha
805cut is offline
iam2fast4u86
May 6th, 2012 02:08 PM
gearheads78
June 15th, 2009 05:30 AM
442_Mustang
April 29th, 2009 01:50 PM
Coltonis
November 29th, 2007 12:24 PM
Kennybill
Ninety-Eight
March 12th, 2007 01:50 PM
Quick Reply: Open heart
