Open heart
Old Jun 2, 2012 | 09:42 PM
805cut's Avatar
Open heart
As some of you know i had some knocking going on with my 350.. today it got really loud like bad real quick, so i decided to pull the intake manifold which ive wanted to do for a while know just curious to see what the inside of that motor looked like... i was suprised to see a pretty clean motor but a few things didnt look right.. i was hopeing to find a broken lifter or something super obvious... no luck
Old Jun 2, 2012 | 10:04 PM
Well, first off congratulations on getting the intake off there.
The knock or tap could be a stuck lifter, or could be more serious. Depends on the actual noise. Chances are you are going to have to delve more deeply than this to find answers. Could be anything from worn bearings to sloppy pistons, spark plug not firing.....
It is nice and clean looking in there, which usually means it received regular oil changes/mtce.
Old Jun 2, 2012 | 10:07 PM
805cut's Avatar
I noticed that the lifters all shake a little bit except a few of them, could that be a sign of being stuck?
Old Jun 2, 2012 | 10:20 PM
I don't think that's your problem. The ones that are tight could just be under load. What I'm thinking more and more based on your initial description is you have spun bearings or a connecting rod problem. That means you'll likely have to pull the engine and rebuild. That's my opinion and I'll tell you I'm not a mechanic, but I pull wrenches on my cars and I bet I'm right.
How many miles on this block?
Old Jun 2, 2012 | 10:55 PM
805cut's Avatar
To tell you the truth, i havent a clue. But im tinking your right as well... DANG i was thinking this engine would last till the 455 was built, oh well here we go again haha
Gbobby
May 6, 2012 02:08 PM
gearheads78
Jun 15, 2009 05:30 AM
442_Mustang
Apr 29, 2009 01:50 PM
Coltonis
Nov 29, 2007 12:24 PM
Kennybill
Ninety-Eight
Mar 12, 2007 01:50 PM
