Oil Filter for 72 350
Old Jun 29, 2018 | 12:18 PM
brown7373's Avatar
Does anyone still make a full size (diameter) oil filter for an Olds V8? What brand and number have you used to interchange with the PF30? I have no confidence that these skinny little filters, the size on my John Deere, can properly filter the oil in a V8.
Old Jun 29, 2018 | 01:16 PM
brown7373's Avatar
I found the NAPA 1258 or 21258 and the WIX 51258 are both the 3.66 diameter, not that skinny (about 2 7/8 diameter) of the Purolators that the parts stores near me sell.
Old Jun 29, 2018 | 01:20 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I just bought a Napa Gold 1258. I usually go with the cheaper but equal quality and size LF222 Hastings oil filter but they were out.
Old Jun 29, 2018 | 02:04 PM
72455442RA's Avatar
Hi
I have NOS
50.00 shipped
old silk screened white body red and blue lettering
this one just sold on ebay ... but I have more ...
Old Jun 29, 2018 | 03:22 PM
RetroRanger's Avatar
72 Olds CS
baldwin b9 is what ive used the last couple changes. Its a 1 qt filter
Old Jun 29, 2018 | 03:32 PM
WIX 51049/NAPA 1049 is the large Oldsmobile filter. This is what I use.
Old Jun 30, 2018 | 09:19 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
More info than you probably need...
WIX 51258 (4.338" height, principal application is 67-80)
WIX51049 (5.178" height, principal application is 59-67) Both are nearly identical, the 51049 being slightly larger. Both are rated at 21 nominal microns.
Baldwin B39 or B9, B9 being the larger version similar to the WIX51049. Its rated at 18 nominal microns.
IMO All other filters inferior or overpriced.
Old Jun 30, 2018 | 09:55 AM
My442's Avatar
Yes - 1 quart filters.
Old Jun 30, 2018 | 10:02 AM
DJS70cutlass's Avatar
Why not use the good old AC PF24? Just got one from Oriley last week and was even made in the USA. It's the large body as well.
Old Jun 30, 2018 | 10:04 AM
Are you SURE it's made in the US? The AC filters I've found have been made in Mexico or elsewhere for at least the last five years. The construction quality dropped considerably on those units. I used to use AC exclusively until I compared one of those newer filters to an old one. The metal on the top plate is about half the thickness, and overall quality is awful.
Old Jun 30, 2018 | 10:28 AM
Yeah it was printed right on the filter. Didn't seem any lighter either. I just ordered another one, I can post pics of it in a few hours once I'm off work!
Old Jun 30, 2018 | 10:53 AM
Disagree on the Hastings filter, US made, I have cut one open , well made and I can get it for $3.00 cheaper than the Napa.
Old Jun 30, 2018 | 10:54 AM
Hopefully, this is a new trend.
Old Jun 30, 2018 | 02:01 PM
Pics as promised. Seems they did switch production back to the US
Old Jun 30, 2018 | 03:11 PM
You mean you agree?
Old Jun 30, 2018 | 03:49 PM
You mean you agree?
The filters you mentioned are all very good, Hastings was not on that list, therefore inferior.
Old Jun 30, 2018 | 04:07 PM
72 Olds CS
I'm skeptical it doesn't say made in USA it says product of usa !
Old Jun 30, 2018 | 04:24 PM
Well if it was produced here you'd think it was made here. I see your point though. I think if it was made in the US with imported components it'd have to say "assembled in USA from US and foreign components" like is seen on a lot of stuff these days. I know it's hard to convey in a pic but the paint doesn't feel like that cheap Chinese paint.
Old Jun 30, 2018 | 04:40 PM
They are included in this discussion. Good point and well said thou...Baldwin bought Hastings in 1995 so one in the same. Like NAPA and WIX. Baldwin/Hastings is a higher quality commercial/fleet filter.
Donaldson and K&N can be included here as well...air filters.
Old Jun 30, 2018 | 07:11 PM
72 Olds CS
I'm skeptical because it doesn't say made in USA it says product of USA not produced, product. Very precise wording that to me means sold in the USA but could be interpreted as it was made in the USA. In today's cost saving efficiency oriented manufacturing the word "made" uses almost 50% less ink than the word "product". Plus the vernacular is made in USA not product of USA so why change from standard terminology to say the same thing. The assembled in USA is exactly the kind of thing I'm getting at. I'm not giving you a hard time I'd like to believe it's made in USA but so many companies engage in misleading the consumer it's Difficult to discern what's actually accurate.
If I was comparing two similar products and one said USA and one said China I would just get the USA one as well.
When choosing on rockauto I frequently select the AC delco professional products as well...the last thing I got was rotors...made in China . They do appear to be decent quality tho.
Old Jun 30, 2018 | 07:19 PM
oldsmobiledave's Avatar
Baldwin
I typically use the WIX or equivalent Napa Gold filter but I noticed that nobody has mentioned the Baldwin filter which is also good.
Old Jun 30, 2018 | 07:34 PM
You are right, I forgot Baldwin owns Hastings. Oil filters have become retardedly expensive up here, the Hastings is one of the few under $10, last Baldwin was similar priced.
Old Jun 30, 2018 | 08:25 PM
jaunty75's Avatar
I wondered about this, too. I have an ACDelco PF61 oil filter in the box sitting on my workbench, and it says "Product of USA" on both the box and the filter itself just like shown above by DJS70cutlass. I did a little googling around, and there are a number of sites and articles that address "Made in USA," "Product of USA", "Assembled in USA," etc.
Here's one from the American Manufacturer's Association.
http://www.ama50.com/american-manufa...bels-standards
The phrase "Made in USA" is regulated by the Federal Trade Commission and can only be used if certain standards are met. From what I can glean, "Product of USA" means the same thing. "Assembled in USA" and similar wording, of course, means only that the part was assembled here but was made from imported parts.
Here's the FTC's own page on the issue.
https://www.ftc.gov/tips-advice/busi...e-usa-standard
The bottom line is that I'm confident that my filter was made in the U.S.
Old Jul 1, 2018 | 07:43 AM
Daves got refrigerator eyes....doh
Old Jul 1, 2018 | 07:56 AM
I have a commercial fleet filter/oil supply company here with a corporate discount. So I pick the Baldwins when I am in that neighborhood. 6 bux or so. I use them for oil analysis too as they sell the kits. They also sell Schaeffer oil products. I'll go for the WIX if I'm on that side of town. I'm lucky as I have 3-4 non-big box parts joints here.
Old Jul 2, 2018 | 04:20 AM
brown7373's Avatar
Thanks for the replies. Seems the 1258 numbers across many of the lines is the right number.
Old Jul 2, 2018 | 05:55 AM
To clarify, 1049/51049 will fit in place of 1258 and it is a physically larger filter with more media area. It will not fit on the 307 motors that use the small filter, however. Well, it actually will spin on, but it rubs on the trans cooler lines.
Old Jul 3, 2018 | 11:13 AM
4SPEED67's Avatar
I use Wix 50149 filters and never a problem
Old Jul 5, 2018 | 04:14 PM
Hammerdrop's Avatar
I recall about a year ago, Car and Driver magazine was track testing a Corvette and experienced an engine failure, that was, in some way, attributed to the OEM oil filter. Since reading that, I will not use an AC filter- only Wix.
pogo69
Nov 15, 2021 04:26 PM
78Cutlass4Speed
Nov 14, 2021 08:49 AM
White_Knuckles
Jun 7, 2015 10:43 AM
455man
Jul 6, 2013 02:14 PM
coltsneckbob
Dec 26, 2011 10:25 PM
