heater hose restrictor?
Inline Tube sells the correct nipple with restrictor for $18. Note that the 1964-70 factory intakes use a smaller NPT than the 1971-up intakes. There is no telling what thread is used on aftermarket intakes.
no, there are no problems, I'm replacing the heater hoses and wanted to put it all back factory, I have all the correct hoses, and I seen reproduction from inline tube, heater hose fitting that goes in the back of the intake, in the ad it says with built in restrictor, so I didn't know if there suppose to be a restrictor in the heater hose or in the heater hose fitting on the back of the intake, or no restrictor at all. my heater works fine right now. I just wanted the correct way to put it back together. thanks! Brian
The reason for the restrictor is to avoid overpressurizing the heater core, leading to leaks. On A/C cars, the heater control valve provides this restriction, but on heat-only cars the restriction is built into the nipple.
FYI, the restriction is simply a smaller diameter hole (1/4" maybe?) in the much larger diameter hose fitting. You should be able to look at the inside of the fitting and see if it is restricted or not.
Pretty sure the SBO Performer, along with the RPM has 3/4" NPT threads.
