Fresh 67 330 needs exhaust system
Old Mar 2, 2022 | 03:21 PM
brianbeez67's Avatar
Looking for recommendations on an exhaust system. I’m leaning towards 2.5”, with cross over pipe. Want a long lasting system.
What’s out there?
Old Mar 2, 2022 | 03:39 PM
I took mine to a local muffler shop, he's an artist. I have long tube headers, used 2.5" aluminized tube, Walker Super Turbo mufflers, and tail pipes turned down at the rear bumper. It's been on there for 10 years and still looks great.
Old Mar 3, 2022 | 05:47 AM
Aluminized system, how does the pipes hold up over the winter? Is your car garage kept? Will try local shops. Car doesn’t run now so i think it might be hard to get an estimate? Will try to keep you posted
Thanks Brian
Old Mar 3, 2022 | 08:03 AM
Thanks Brian
The pipes are holding up very well. For the first 5 years after the exhaust was done the car was still being used as a daily driver. Driven in snow, sleet, ice, and rain. Yes the car is garage kept and still drives in the rain, not so much in the frosty stuff anymore since I retired. You can probably call your local shops and get a rough estimate.
Old Mar 3, 2022 | 10:39 AM
x2
I've had a local exhaust shop do work on my 71 and my 96. My truck is next on the list. You'll get better service and exactly what you want from a pro compared to a catalog ordered exhaust.
Old Mar 3, 2022 | 11:55 AM
Sugar Bear's Avatar
2.5" is big for a 330 CID, smaller may make a cleaner and easier install...just food for thought. IIRC in big car '68 455 dual option from the factory was 2 1/4".
Good luck!!!
Old Mar 3, 2022 | 01:31 PM
brownbomber77's Avatar
Good luck!!!
I'd second this. 2" dual exhaust is plenty, easier to bend around the axle, a hair more ground clearance,
Old Mar 3, 2022 | 02:29 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Are you using manifolds? A stock motor? The SB manifolds only have 2" outlets, even the Thornton are only 2 1/8". I found the 2.25" dual exhaust really nice on my Olds powered trucks. The H pipe quiets it slightly. The 2.5" custom X pipe exhaust on my Cutlass has a slightly higher pitch but sounds good. If you want a mellow sound, Dynomax Superturbo or other turbo mufflers like Summit are quiet but above stock.
Old Mar 3, 2022 | 07:41 PM
Cutlass Fan's Avatar
I had a local Minute Muffler do mine. 2.25" and Dynaflow mufflers. Sound nice, no droning but I would have liked it slightly louder.
garyfoust
Apr 28, 2020 06:34 PM
Drews67Cutlass
Feb 28, 2020 11:51 PM
67cutlassguy
Jun 10, 2018 06:12 PM
Roger60
Aug 7, 2016 06:49 PM
seanm12
Feb 22, 2015 01:49 AM
