Exhaust Note
Old May 23, 2025 | 02:24 PM
cdrod's Avatar
Rodney
Exhaust Note
I built a 350 stroker using a build plan from Mark Remmel for my '72 442 convertible. The exhaust is a true duals arrangement (without an "H or "X" pipe) so the LH & RH banks are completely independent of one another. The exhaust signal at the LH tail pipe is very "choppy", I can feel very distinct, individual pulses; but the RH tail pipe is much more smooth, can't feel the pulses like the LH side. I'm still dialing in the engine tune, and the idle is choppy with about 15inches of vacuum at idle; CR=10:1, aluminum heads, headers, cam card is below. It has a throttle body EFI from Fitech and is running a little rich so off-the-line acceleration is a bit sluggish but still pulls strong and breaks the tires loose on the 1-2 upshift. The LH muffler seems to rattle a little where the RH side does not, I'm running DynoMax Super Turbos. Could this just be a bad muffler or signs of bigger problems or engine tuning? This is my first, high-performance Olds build so I'm in new territory as far as my experience.
Looking forward to your responses.
Rodney
Old May 23, 2025 | 06:51 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Test your wires, inspect the spark plugs and a compression test might not be a bad idea as well.
Old May 23, 2025 | 07:02 PM
I'd double check the exhaust hangers on the left side if it seems to rattle.
Old May 23, 2025 | 07:40 PM
Sugar Bear's Avatar
Triple check the firing order and do a compression test. A power balance test could also be done by checking to see if each cylinder is producing similar power. If pulses are felt in the exhaust it could be a simple misfire or hopefully not a leaking/sticking valve.
Old May 27, 2025 | 05:58 PM
cdrod's Avatar
Rodney
Thanks for the suggestions. I pulled the spark plugs back in January and cylinder#3 looked a bit fouled. Cylinder 3 is on the LH bank which has the hard exhaust pulse. What's the best way to check for a misfire? Bad plug wire? what else should I look for? Here's a pic of the plugs from January. I cleaned and reinstalled the plugs with a new O2 sensor and the car ran better but still not right.
Rodney
Old May 27, 2025 | 06:52 PM
Sugar Bear's Avatar
Do a compression test.
Old Jun 4, 2025 | 08:57 PM
Cutlass Fan's Avatar
Just curious as to why you would build a 350 instead of a 455 for your 72 442.
Old Jun 7, 2025 | 04:53 PM
cdrod's Avatar
Rodney
Prefer the lighter weight small block (even lighter with aluminum heads & intake) and needed less than 400 HP..
79cut
May 1, 2025 08:26 PM
joshduty
Aug 10, 2022 08:17 AM
friesjh
Sep 2, 2020 06:54 PM
805cut
Jun 8, 2012 03:15 PM
mp71conv
Jun 8, 2009 04:09 PM
