Edelbrock Intake
Old June 7th, 2010, 08:48 PM
nuttkaze's Avatar
Edelbrock Intake
I looking into getting a Edelbrock intake and I'm want to know the differences between the performer Intake and the RPM performer intake? I also see that some has EGR...what is EGR? Do anyone have pics of the polished intake installed!!!
If it matters, I plain on keeping my Quadrajet Carb and getting a 442 air cleaner...
nuttkaze is offline
Old June 7th, 2010, 09:56 PM
Proud Viet Nam Veteran
redoldsman's Avatar
The Performer is pretty much a stock 4 barrel intake but made of aluminum. Weight savings is the biggest advantage. The RPM Performer is a dual plane high rise that will benefit from a cam and other modifications. EGR is exhaust gas recirculating valve. What year engine are you putting it on? If you are not doing any other modifications, the Performer will probably be best for you.
redoldsman is offline
Old June 7th, 2010, 10:12 PM
nuttkaze's Avatar
here is the master plain!!!
Intake- EDEL RPM Performer or performer
Carb-Rebuild the factory Quad which is a 4-Barrel
Cam-Depends on compression.."give opinions"
True Roller Timing chain-Suggestinos please on what kind? What about a double roller?
Heads-clean up the original #7 w/ 2.00 or 2.07 intake valves (What the difference of the intake valves?), but still give suggestions!!!
Pistons-What kind..looking to get about 9.75 to 1..no higher!!!
Headers-ceramic coated long tube, but I'm unsure on which ones to go with?
Gears-3.36 posi
Torque Converter-probably not if so very small!!!
Transmission-reduild with a shift kit..who has the best shift kits?
HEI Ignition-All MSD
nuttkaze is offline
Old June 8th, 2010, 12:24 AM
nuttkaze's Avatar
What the benefits of EGR and do I need a intake that has it?
nuttkaze is offline
Old June 8th, 2010, 05:25 AM
You don't have an EGR valve on your car if you have a stock 71 Cutlass. EGR would pump part of the combustion gases back into the engine to lower the combustion temperature. This would prevent the formation of NOx. It is an emissions control device.
Olds64 is offline
Old June 8th, 2010, 01:24 PM
nuttkaze's Avatar
I guess I dont need a intake with EGR..Thanks redoldsman & olds64!!!
I posted what I wanted to do with the 350 above, so what intake will be better soothed for my application? Do anyone have pic how the polished intake looks installed vs. the natural intake..
nuttkaze is offline
69CutlassAlex
July 30th, 2013 08:18 AM
svnt442
July 17th, 2011 04:43 PM
70Cutlass_408
June 24th, 2011 07:55 AM
71cuttyS
October 31st, 2007 04:58 PM
mitsudave
February 26th, 2007 12:30 AM
Quick Reply: Edelbrock Intake
