Edelbrock Intake
Edelbrock Intake
I looking into getting a Edelbrock intake and I'm want to know the differences between the performer Intake and the RPM performer intake? I also see that some has EGR...what is EGR? Do anyone have pics of the polished intake installed!!!
If it matters, I plain on keeping my Quadrajet Carb and getting a 442 air cleaner...
The Performer is pretty much a stock 4 barrel intake but made of aluminum. Weight savings is the biggest advantage. The RPM Performer is a dual plane high rise that will benefit from a cam and other modifications. EGR is exhaust gas recirculating valve. What year engine are you putting it on? If you are not doing any other modifications, the Performer will probably be best for you.
here is the master plain!!!
Intake- EDEL RPM Performer or performer
Carb-Rebuild the factory Quad which is a 4-Barrel
Cam-Depends on compression.."give opinions"
True Roller Timing chain-Suggestinos please on what kind? What about a double roller?
Heads-clean up the original #7 w/ 2.00 or 2.07 intake valves (What the difference of the intake valves?), but still give suggestions!!!
Pistons-What kind..looking to get about 9.75 to 1..no higher!!!
Headers-ceramic coated long tube, but I'm unsure on which ones to go with?
Gears-3.36 posi
Torque Converter-probably not if so very small!!!
Transmission-reduild with a shift kit..who has the best shift kits?
HEI Ignition-All MSD
Gears-3.36 posi
You don't have an EGR valve on your car if you have a stock 71 Cutlass. EGR would pump part of the combustion gases back into the engine to lower the combustion temperature. This would prevent the formation of NOx. It is an emissions control device.
I guess I dont need a intake with EGR..Thanks redoldsman & olds64!!!
I posted what I wanted to do with the 350 above, so what intake will be better soothed for my application? Do anyone have pic how the polished intake looks installed vs. the natural intake..
69CutlassAlex
July 30th, 2013 09:18 AM
svnt442
July 17th, 2011 05:43 PM
70Cutlass_408
June 24th, 2011 08:55 AM
